NBG6515 bricked after firmware upgrade.
MAK
My NBG6515 was bricked today after upgrading firmware, very strange, I have upgraded using the web interface twice before without problems, the only difference is this time I had to download the firmware file (V1.00(AAXS.4)C0_20171113.bin) manually and upload it to the router using the web interface.
Currently only the power LED comes on, I tried using the reset button following the procedure in the user guide, didn't help. Router is not working in any mode (repeater/router/AP). Plugging an Ethernat cable from router to PC, connection light comes ON but no IP address is assigned to PC, tried assigning address to PC in the range of 192.168.1.x manually and couldn't ping the router on either .1 or .2 address.
Was wondering if there is another procedure to restore the firmware? maybe via USB or using some application that can access the router over some different protocols?
Please help.
Happy holidays to all.
Mohammed.
#Router_December
Please help.
Mohammed.
#Router_December
@MAKThank you for choosing Zyxel product.In order to provide you with a better assistance,We have contacted you via private message to get information.Please check you message box. Thanks.1
Thank you Zyxel_Kelly, replied to your message.0
Zyxel provided exceptional service, I got my router back today, all working now
, very fast and efficient service considering the holidays period. Many thanks to all the people who made this possible, well done.
My NBG6515 is doing the same after updating via the web interface
Power LED on and that it.
How can i recover the bricked device ?
@TaKulaMany thanks for choosing Zyxel product.In order to provide you with a better assistance,We have contacted you via private message to get information.Please check you message box. Thanks.0
Hi I have the same problem with mine, updated today and its not working anymore. Please help urgently0
@kt3000In order to provide you with a better assistance,We have contacted you via private message to get information.Please check you message box. Thanks.0
Hello:
I have a similar problem after firmware upgrade with my N4100, only light on is Power and have tried the reset procedures mentioned, however, I have no response from the device.
Please help, thanks.0 -
Hi - I have a similar bricked issue with my P870HW-51Av2. Power light just blinks, does not book and reset does not work. Any help you can give would be appreciated!
Thanks0 -
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
