Firmware upgrade!
elcapito
First I receive this:
I select"Start", an after some time I get this:
I select "Confirm", and I get this again:
This goes on and on without anything more happening. I tried to restart the "main" Multy X (now in bridge mode" but the cycle repeats itself. The Wi Fi is working well but............anyone with a good solution?
#MultyX_December
#MultyX_December
Hi elcapito,May I know your Multy X app version and the upgrade steps?About this problem: Are you upgrade the latest app version first? After that, change to bridge mode, then upgrade to the latest FW of Multy X?1
Endless! Thanks for taking time to help!
As you can see I have been contacted by Zyxel to rectify my problem. I will wait for their solution, but in the unlikely event of them coming short of a fix, I will try your suggestion!
Thanks again!1 -
Problem is now solved! I already had the latest issue. The prompt to upgrade is now removed!1
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
