LTE4506-M606 often occurs disconnection
#LTE_December
it is V1.00(ABDO.3)C00
1. How often does the LTE disconnection happen? Is there any pattern, for example, every hour?
2. Does it help if you configure the Cellular Network Mode (Internet > Internet Status) to “3G Mode”?
3. Please take screenshot of the Internet Status page (internet > Internet Status), as the following image shows.
Please share the general signal level and the Internet Connection Method setting.
4. When the LTE4506 disconnects from the Internet, please go to the Network Selection page (Internet > Network Selection), select the PLMN mode to “Manual” and press “Scan”.
It takes about 1 minute for the LTE4506 to scan the nearby networks.
Please take screenshot of the scan results, and please also identify if any of the scanned networks is your Internet service provider.
1. Please take screenshot of the Internet Status page (internet > Internet Status), as the following image shows.
I would like to know the general signal level and the Internet Connection Method setting.
2. When the LTE4506 disconnects from the Internet, please go to the Network Selection page (Internet > Network Selection), select the PLMN mode to “Manual” and press “Scan”.
I would like to know whether your 3G service provider is in the scan results when the 3G services disconnect.
3. In your reply, what does “LTE4506-M606, about 6 will be linked to this device” mean?
What does 6 refer to, 6 minutes?
we will contact you through private message,please check your message box.
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
