Fritzbox switch to Multy X
Tauchloewe
Hi all, I am very happy with Multy, but for now it is only used in Bridge Mode behind a Fritzbox. I would like to switch this so that Multy will do the complete control but Fritzbox was set up long a go from a pro and has some Port / routing settings. Any one with some ideas what I need to take care of?
thanks
thanks
#MultyX_January
Best Answers
My suggestion is to keep current network environment, Multy X as bridge mode.Fritzbox as main router to control advanced setting, Multy X is provided wireless signal for your client device. It would be better.Because Multy X does not yet to support some advanced setting such as VLAN, Firewall Rule, Bandwidth Management ...0
-Fritzbox - Multy (WiFi) - switch for the connected devices-Fritzbox to Multy and Fritzbox also direct to switchIt's not different. Because your Multy X is bridge mode, switch is connected to Multy X or Fritzbox, all devices still in the same network which control by Fritzbox.0
> Fritzbox was set up long a go from a pro and has some Port / routing settings.Are you set up some advanced setting on your Fritzbox or it's default setting on your Fritzbox?0
good question. I got some fix IP Adressen for my NAS and Ports open. As I said... I am not that good with these things ;-(
Hi, ok, thanks for that open answer. Sad to hear as I want to use the device control etcOne lasat question: Whats better then, Fritzbox - Multy (WiFi) - switch for the connected devices or Fritzbox to Multy and Fritzbox also direct to switch?
Thanks!0 -
great, thought so but was not sure. Thanks!!
- 431 Beta Program
- 2.6K Nebula
- 164 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
