SBG3500-N bridge mode/VLAN 4 IPTV
Kasper
I have a SBG-3500-N with the most recent firmware. This is connected on a bonding VDSL line from the dutch provider xs4all.
Xs4all deliveres their triple play services through VLANS and uses VLAN 6 for internet and VLAN 4 for IPTV (VOIP is not relevant).
I can get the internet working without any issues. However the TV on VLAN 4 i can't get to bridge to a LAN port.
I have tried creating a additional WAN interface with VLAN 4 tagged and then creating a LAN VLAN 4 tagged and untagged (i tried both) to LAN port 4.
Nothing what i try will result in the TV settopbox getting a valid IP address from the IPTV platform on VLAN 4.
I wondering what i am missing here because i have had this working with different hardware in the past. Unfortunately this zyxel is one of the few that supports bonding so i would like to get it working on this.
Any input/help would be greatly appreciated.
Kasper
#Biz_Security_January
Kasper
As your scenario,
It seems the SBG3500 does not support triple play services......0 -
Well it does work with the additional WAN interface setup as bridge on the right VLAN. I get to watch tv when i plug the Settopbox into the zyxel WAN port.
Now what doesn't work is to confine the vlan 4 (because this is heavy multicast) to one LAN port and transfer the traffic to the next switch.
I have tried creating a LAN interface group for vlan 4 and set for example port 4 to tagged. Then on the next switch zyxel port 4 is connected to port 2 for example. Set that port to tag vlan 4.
Then create a access port untagged to connect the STB to in this example port 8.
But i don't get a IP from the IPTV platform. But the TV signal including all functionality like live pausing recording etc. is working when a STB is connected straight to the SBG.
- 588 USG FLEX H Series
- 477 News and Release
