VMG8924-B10A Shared Hard Drive/Flash Drive
dashard
I am trying to connect either a hard drive or flash drive to USB 1 on the router. I would like to have access to it via Windows Explorer operating system Windows 10.
However Windows Explorer doesn't seem to be able to see the folder I have created( Named Test) I am using the following address to trying to access it \\192.168.1.1\Test.
Does anyone have any idea how I can rectify the situation?
Many thanks
#CPE_February
Hi Rory,Many thanks for your reply. After a googling session I had come up with the same conclusion to the issue.I am pretty sure SMB1.0 support in Windows 10 after the recent update was going to be the issue. I have not enabled SMB1.0 support as of yet, because I was a little concerned about any potential security issues on my system. And to be honest I only wanted to connect a hard disk to the router to test my LAN speed anyway.Will temporarily enable SMB1.0 support just to satisfy my curiosity that this is indeed the issue. Thank you once again for your kindness in replying to my posting.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
