Windows 10 Can't See USB Share (XMG3512-B10A)
HopuefulJ
HopuefulJ Posts: 3  Freshman Member
edited February 2018 in Smart Home Product
I'm sure its something simple so my apologies in advance. Basically I insert my USB stick into my Zyxel
XMG3512-B10A  but my Windows 10 PC apparently cannot map to it.
Any help would be great!
#CPE_February
  • Rory
    Rory Posts: 120  Ally Member
    @HopuefulJ
    You can try to enable SMB1.0 in Win10 as below:
    https://homeforum.zyxel.com/discussion/comment/1716#Comment_1716
  • Ansa
    Ansa Posts: 44  Freshman Member
    Just tried it like Rory mentioned to enable the SMB1.0.
    Then it need to put the path into the folder column like:
    \\192.168.1.1\usb1_sda1  (My LAN port IP address is 192.168.1.1)
    Afterward, my windows 10 can map it and shown as below
  • HopuefulJ
    Thank you guys, I think Rory's suggestion "You can try to enable SMB1.0 in Win10" got me closer.
    1. After following that step and restarting my PC I now see this.
    2. So Ansa's suggestion resulted in this progress!
    3. So then I clicked 'Diagnose' and got this
    I l
     4. So I double checked my share just to make sure.
    Am I missing something? I even tried mapping again using this path==>     \\192.168.200.1\mnt\usb1_sda1\ZYXEL    but still the 'diagnose' result is that windows can't find 'mnt'.
  • Rory
    @HopuefulJ,
    How about use following path?
    \\192.168.200.1\ZYXEL
  • HopuefulJ
    Rory,
    I cant find your last message but I wanted to thank you for suggesting the share path as shown below following your SMB1.0 suggestion.  Your SMB1.0 suggestion is what made this share path work.
    \\192.168.200.1\ZYXEL       <<<< THIS WORKED!
    And thanks to  everyone for your help .
    Sincerely...
