Reset nsa310
HarryK64
How can I overwrite firmware on the nsa310 with a usb pin that is installed universal_usb_key_func-2015-10-12.zip on it, it has been used for TDC backup disk. I would like zyxel firmware installed on it, I have reset it on the button, with a paper clip and after number two beep I take it away and there are 3 beeps, I enter 192.168.1.5 in my browser, but I can not get in contact nsa310. I have a network cable connected between the computer and the nsa310. can you help me? Best regards Erik
#NAS_February
#NAS_February
Do you want to change use from TDC to Zyxel official version?
If yes, that I recommand you to ask TDC for the way to do it.
Yes, I want to, and have contacted TDC so waiting for answers. where do i find usb_key_func.sh.telnet two usb_key_func.sh.2 that can be used with software for a usb pin to get in touch with nsa3100
no help from TDC, so I hope there is someone here who can help me access nsa3100
Greetings! I bought the NSA310 TDC. I want to install the standard firmware NSA310. Links nas-central.org do not work. I can not find the files force_flash.zip or TDC_to_OBD.zip anywhere. Help me please.
- 588 USG FLEX H Series
- 477 News and Release
