Multy X to be compatible with Homekit/Siri/homepod?
Lomprayah
Do you mean that you want to use HomePod to control Multy X?Such as turn on/off Multy X LED, turn off guest Multy X WiFi, ... via voice?
BTW, when Homekit and HomePod are connecting the same WiFi network in your home, it will work properly.Set up and use HomePod: https://support.apple.com/en-us/HT208241
May I know do you encounter the problem?0 -
Hi, but i have not seen anywere that Multy X is compatible with Siri/homekit?, only with Alexa0
Multy X works with Amazon Alexa, it means you use voice to control Multy X via Amazon Alexa.Please refer to user guide page 37.But you still can use HomePod to do what it can do except use voice to control Multy X.0
Hi
What can i then use Homepod/Siri to do with Multy X?
Anders0 -
Currently, Multy X does not support through HomePod to control it.Thanks for your feature request in Multy X and we will evaluate it.And I have moved this post to Ideas Discussions.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
