Log in to http://zyxelsetup
sveiniversen
Hello
I have used Exibel WRE6505 for a while without any problems.
But, now I have chanced my home nettwork and need to reconfigure Exibel.
I have tried to reset it as described in the documentation (hold wps button for 5 sec) and was hoping that would get me acces to log in on zyxelsetup, but no luck.
How do I log in again?
sveiniversen
#Repeater_March
sveiniversen
#Repeater_March
Hi
Ensure you have connected to the WRE6505 network before you try to access zyxelsetup
Anders0 -
Problem is I have reset the WRE6505 and don't know how to connect without login in. And I can't seem to log in... Sircular problem I guess.
i think the default user name is admin, and password 12340
@sveiniversen,
Normally, you should be able to access the WebGUI via http://zyxelsetup
Maybe you could try it with the following steps:- Press and hold the WPS button for more than 5 seconds (no longer than 10 seconds). The power LED will start flashing.
- Connect your PC to the Ethernet port of WRE6505.
- Open your browser and access http://zyxelsetup
- If you are not able to access the WebGUI in step3, please try to assign a static IP address, 192.168.1.100 for example, to your network card.
- Try to access http://192.168.1.2 via the browser.
PS. Remember to change the static IP of your network card back to the original settings after you finish the configuration of WRE6505.
Hope this method can help you to access the WebGUI of your WRE6505 successfully.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
