Write performance for Zyxel NAS540
beuford
I just purchased a new NAS540. I loaded it with a single HGST 4TB NAS drive (7200RPM, 128MB cache and a SATA 3 interface) for testing. It came with version 5.20 firmware, but I've upgraded it to version 5.21 firmware. I purchased this to replace a WD MY Cloud 4TB. All Internet apps were disabled for testing (media server, iTunes server, etc).
Testing was done over a direct 1Gb Ethernet connection between devices. Test computer is an Apple Macbook Pro 15" (quad-core i7,16GB RAM, 256GB SSD) using a Thunderbolt to Ethernet adapter.
When transferring from the NAS to the Mac (read) I get ~ 115MB/sec, but when transferring from the Mac to the NAS (write) I get only ~45MB/sec. For the My Cloud I get 115MB/sec read and 63MB/sec write.
I kind of expected better performance from the NAS540 relative to the My Cloud; what gives? Any ideas where I can improve performance?
Thanks,
Beuford
#NAS_March
Thanks,
Beuford
#NAS_March
I kind of expected better performance from the NAS540 relative to the My Cloud; what gives?As far a I know the My Cloud has the same processor as the '540; a Mindspeed Concerto 2000. So I'd expect equal performance. (And at least of a '540 I know it can do better than 63MB/sec)Any ideas where I can improve performance?
Have a look in the webinterface which process is eating most of the CPU cycles, when writing.
It's usually the web interface....
Funny, though, how Python is always consuming 12 - 20% of the CPU. Memory is nowhere near maxed out, but processor ^ 100% frequently during writes. It's the file system and python competing for CPU resources.
I don't have the NAS540 connected to the internet (security); could this be causing problems? Is there a process trying to "phone home" that might be the cause of the high python utilization?
You'd think it would give up when it realized that it didn't have a default gateway route...
beuford0 -
OK - So here is something interesting. It seems that the processor in my NAS540 is a bit slower than anticipated. From the /proc/cpuinfo files of my NAS540, MyCloud Gen 2 and a MyCloud Gen 1:NAS540:*****Processor : ARMv7 Processor rev 1 (v7l)processor : 0BogoMIPS : 1196.85processor : 1BogoMIPS : 1196.85Features : swp half thumb fastmult vfp edsp neon vfpv3 tlsCPU implementer : 0x41CPU architecture: 7CPU variant : 0x2CPU part : 0xc09CPU revision : 1Hardware : Comcerto 2000 EVMRevision : 0001Serial : 0000000000000000*****MyCloud Gen1:*****Processor : ARMv7 Processor rev 1 (v7l)processor : 0BogoMIPS : 1299.25processor : 1BogoMIPS : 1292.69Features : swp half thumb fastmult vfp edsp neon vfpv3 tlsCPU implementer : 0x41CPU architecture: 7CPU variant : 0x2CPU part : 0xc09CPU revision : 1Hardware : Comcerto 2000 EVMRevision : 0001Serial : 0000000000000000*****MyCloud Gen2:*****processor : 0model name : ARMv7 Processor rev 1 (v7l)BogoMIPS : 1594.16Features : swp half thumb fastmult vfp edsp neon vfpv3 tlsCPU implementer : 0x41CPU architecture: 7CPU variant : 0x4CPU part : 0xc09CPU revision : 1processor : 1model name : ARMv7 Processor rev 1 (v7l)BogoMIPS : 1594.16Features : swp half thumb fastmult vfp edsp neon vfpv3 tlsCPU implementer : 0x41CPU architecture: 7CPU variant : 0x4CPU part : 0xc09CPU revision : 1Hardware : Marvell Armada 375 (Device Tree)Revision : 0000Serial : 0000000000000000*****Can someone PLEASE explain why my NAS540 has a slower processor than a Gen1 MyCloud?!?Beuford0
Sorry for the repeated posts - I didn't see the note at the bottom stating that the post had to be approved. I assumed something had gone wrong and tried to repost (again and again...).
Sorry!
Beuford0 -
Short version: /proc/cpuinfo shows a 2-core processor running at ~1200 BogoMIPS per core on the NAS540, but ~1595 BogoMIPS per core on a My Cloud Gen 2 and ~1300 BogoMIPS per core on a MyCloud Gen 1.
Seems a little strange that the NAS540 would report a slower speed than an old My Cloud... That explains a lot, though, since the performance is more on par with my old Gen1 My Cloud.
Beuford0 -
From a web site that records specific information from NAS systems, we have this /proc/cpuinfo output for the same model (NAS540):
**********Processor : ARMv7 Processor rev 1 (v7l)processor : 0BogoMIPS : 2387.14processor : 1BogoMIPS : 2393.70Features : swp half thumb fastmult vfp edsp neon vfpv3 tlsCPU implementer : 0x41CPU architecture: 7CPU variant : 0x2CPU part : 0xc09CPU revision : 1Hardware : Comcerto 2000 EVMRevision : 0001Serial : 0000000000000000**********
My system reports almost exactly HALF of the BogoMIPS reported here, even though everything else in the output matches and the machines are the same.
Any ideas?
Beuford0 -
That's fishy. I guess your data comes from zyxel.nas-central.org. That NAS540 is mine. In that time it was running firmware 5.00. Meanwhile it's upgraded to version 5.11. And guess what? The output of /proc/cpuinfo is changed. It now runs 1196.85 bogomips.
Don't know how I must interpret that. On a 1.2GHz Armv7 CPU I'd expect something like 1200 bogomips. I'm pretty sure the '540 has a 1.2GHz processor. Some Googling around gives no conclusion about the MyCloud. I can find both 1.2GHz and 650MHz.
The bootlog of firmware 5.00 shows[ 0.190282] xor: measuring software checksum speed [ 0.240157] arm4regs : 140.800 MB/sec [ 0.290111] 8regs : 147.200 MB/sec [ 0.339960] 32regs : 89.600 MB/sec [ 0.390023] neon : 147.200 MB/sec [ 0.390031] xor: using function: neon (147.200 MB/sec)
while the current bootlog shows[ 0.192035] xor: measuring software checksum speed<br>[ 0.240014] arm4regs : 2130.000 MB/sec<br>[ 0.289997] 8regs : 1398.000 MB/sec<br>[ 0.339981] 32regs : 1186.400 MB/sec<br>[ 0.389974] neon : 1384.400 MB/sec<br>[ 0.389982] xor: using function: arm4regs (2130.000 MB/sec)<br>
which is not even comparable. So my guess is that there were some timing issues in the 5.00 kernel. Which has impact on bogomips measurement.
Thank you for the revised info.
However, I am still at a loss with respect to the poor write performance of the NAS540.
I'm only getting 44MB/s writes (copy from computer to NAS, direct 1Gb link, 10GB file). The My Cloud gen 1 does about the same, and the gen 2 beats it by 50% (~64 to 66 MB/s. Reads are at 115MB/s.
Note that I am now running 2 1TB drives in a RAID 0 configuration.
Any ideas??
Beuford0 -
UPDATE
OK, so something I left out - I'm using a Mac.
I pulled out my wife's laptop running Windows and ran the same tests - and got 90-100MB/s for both reads and writes. What the ... ??
So what is different about AFP that causes a 50% performance hit? I tried all three of my Macs and all had similar results. I also tried to use an SMB connection from the Mac, but got ridiculously slow throughput (12MB/s).
Since the WD My Cloud gen 2 does better own writes from the Mac (64MB/s vs 45MB/s) but is otherwise a similar system to the NAS540, I have to believe it's either an AFP version or configuration issue. Any suggestions for improving AFP performance with the NAS540?
Thanks in advance!
Beuford0 -
I never looked at AFP before, and don't know much about it's quirks.
As Samba is fast, it makes no sense to look at disk&network performance. (Although that is other hardware. You could measure network throughput using iperf, which is included in the RandomTools package , provided iperf is also available on your Mac)
My first action would be to compare the configuration. For the '540 you can find it in /etc/netatalk/afp.conf. Do you have shell access to the MyCloud as well? I'd expect an afp.conf somewhere in /etc/. If not, you can runps | grep netatalk
to see which file it got specified. Reading the man page I don't see many options which I would expect to have big impact on transferring a single file. Maybe tcprcvbuf.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
