Can I sync two NAS540's over the internet?
nwmike
I want to mirror my main NAS540 to another one at a different location. Can this be done so that is syncs changes dynamically?
Hi @nwmike
With the scheduled backup and rsync option, you can make backup with a distant NAS. You have option to choose external location and use IP (perfect only with a fix IP) or using dynamic domain name. You have to open port on the way in the distant router for accessibility (default port for rsync is 873).
Here screenshot, but sorry it's in french... After the 3rd screenshot you have to continue the procedure with choice of the folder destination, date, hours, ... :-)
Hope this help you !!!
Thank you for this! I will look into setting this up, Merci!
Is there any way to do over CLI?
This aplication only allows to rsyc FROM the Zyxel and not TO the Zyxel.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
