Use NAS326 as Backup for FreeNAS Server via rsync and ssh authentification
warp
I would like to use my NAS 326 as backup server for my fast FreeNAS Server using rsync, but I have troubles to set up rsync push, both via SSH or rsync module
#NAS_February
#NAS_February
rsync push? In the meaning that your FreeNAS server will push the data to the '326?
I don't know about which rsync module you are talking. AFAIK the NAS has a backup package, which features 'zysync', a zyxel specific rsync derivative, which is not compatible with rsync.
To get rsync running, you'll need a 3th party implementation. RandomTools contains a version of rsync. To use it as server you'll have to provide a rsync.conf, and start the daemon. To get that done, you can put a script in /i-data/sysvol/.PKG/RandomTools/etc/custom_startscripts/, which will be executed on boot.
Oh, and you'll have to disable/remove the ZyXEL backup package. zysync uses the same port as rsync does, and so holds back the stating of rsyncd.0 -
I just tested a solution that worked for me:
http://zyxel.nas-central.org/wiki/3rd_party_zypkgs#NAS5xx.2C_NAS326
- 588 USG FLEX H Series
- 476 News and Release
