New firmware - Any changes to how many nodes supported?
Joakim
Joakim Posts: 15  Freshman Member
edited April 2018 in Multy WiFi System
Thanks for a great update on the FW and App.
Is there any change for how many Multy X nodes that are supported? I would like to use 4.
#MultyX_March
  • Zyxel_Steven
    Zyxel_Steven Posts: 246  Zyxel Employee
    Primary Multy --> Second Multy
    Primary Multy --> Third Multy --> Fourth Multy
    Yes, it can be hybrid Star/Daisy chain.
  • Zyxel_Steven
    edited March 2018
    With Daisy Chain, it can support maximum 3 hops, 4 nodes. But the performance will be declined very much with more hops.
    For example:
    Multy X Node_1 ))) Hop1 ((( Multy X Node_2 ))) Hop 2 ((( Multy X Node_3 ))) Hop 3 ((( Multy X Node_4
  • Joakim
    Thanks.
    My setup would be hybrid star/Daisy chain.
    Meaning:
    Does this setup make sense?
  • Alexander
    Alexander Posts: 2  Freshman Member
    @Joakim,
    If these 4 Multy evenly covers your whole space and they are in moderate distance between each other, It should work fine. End devices near 1st/2nd/3rd would work great, only rest near 4th would have little speed drop due to more hops. You can do some speedtest with your setup.
