I can't connect to my NAS using zCloud
Chanakan5591
I can connect to my NAS using ZyXel Drive on WAN network but when i connect to it using zCloud it cannot connect to it. help me please. I am using NAS326
#NAS_April
#NAS_April
I'm fixed it myself. Thank you for your help.
Hi @Chanakan5591
zCloud is connecting to NAS via http protocol as default port 80, and seems you have paired your NAS326 to myzyxelcloud, but the http port would be changed by cloud if the port is the same as router's, so you have to check the UPnP setting in myzyxelcloud and enable http feature and see the port number.
And you have to use NAS_DDNS:port in address in zCloud to access your NAS326, such as myNAS326:8080
This should be working for you.0 -
@Ijnrsi I'm already try that but my router block the 80 port. I try to connect to it with 8080 port but it failed too.0
@Chanakan5591
The port 8080 is sample, that you have to check your UPnP setting.
You can share the screenshot for UPnP setting and zCloud, I think the port you used is incorrect.0 -
@Ijnrsi I cannot set the Http WAN port to 800
@Chanakan5591
You can first check if the URL can be accessed via browser,
if not then you have to check your URL.0 -
I cannot access it via any browser and the URL are correct0
That is very weird, since your UPnP port now is mapped, but you are not possible to access your NAS over Internet.
I am curious if you turn on the WAN access on your router, is it possible to access your router over internet?Another way to you, maybe you can try to setup a port forwarding to make sure if WAN access is workable without through myzyxelcloud. And your problem of port 80 on UPnP or port forwarding rule can't be used for NAS, the reason is router already used the port as default http port, so if you want to access your NAS over internet, then you have to change NAS web managament port from 80 to other and also configure the port forwarding rule to map to the new port.
I'm having exactly the same problem with my NAS542. Did you find a solution?
I connect to mycloud from the browser, but from zCloud I get the same "Fail" message.
I also try ZyxelDrive. It connects and I can see the main directories like the system ones (photos, music, etc.) and my own, but trying to enter any of them I get "Connection Error. (205)".
Please, help.0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
