instable /blocked internet connection with Multy X
Zuio
1. we often experience loss of connection . to cure it i have to go offline with the Ipad, macbook or even android mobile, and reconnect. it also helps to change the network 2.4MHz to 5 MHz or reverse.
2. we turn off our hotspots at night. the slave hotspot with a timer. if i am surfing connected on the main hotspot i have also to reconnect or change frequency.
I have installed the latest firmware only a view days ago but still the same.
regards
#MultyX_May
regards
#MultyX_May
I also have a similar problem. Does your problem the same as below picture?
"It also helps to change the network 2.4 MHz to 5 MHz or reverse." -> How to help?
May I know what's your meaning about second point? How many Multy X units you have?0 -
We have two Multy x.
About your picture, until now i haven‘t seen something similar.
Some how i think it has to do with the Connection ID witch expires, an needs to be Updates or so.
In order to provide you with a better assistance, we have contacted you via private message. Please kindly check your message box.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
