Multy extension
Hausi
Hausi Posts: 2 image  Freshman Member
edited May 2018 in Multy WiFi System
Put the Zxycel multy in operation today. I'm very happy. Easy setup, running. Only I have a problem: in some rooms I need a LAN connection, the Zxycel multy is not nearby. Is there a WLAN adapter with LAN connection that works with the multy? Similar to Devolo?
#MultyX_May
  • Zyxel_Steven
    Zyxel_Steven Posts: 246 image  Zyxel Employee
    Not sure what do you mean, is it a powerline device or ...?
    Can you explain more detail what is your needs?
  • Hausi
    I need a LAN connection in one of my children's children's rooms.  The WLAN is enough for iphone and ipad but other devices need LAN. This I wanted to enable my third Zxycel.
  • Zyxel_Steven
    Multy X is not supported wireless client mode.
    You need a Wireless Extender to connect your LAN devices.
    For your reference:
    https://www.zyxel.com/products_services/home-wireless_extenders.shtml?t=c
    Example topology:
    Internet---<WAN>---1st Multy X)))<WLAN>(((2nd Multy X)))<WLAN>(((Wireless Extender---<LAN>---LAN Device
