[nas542] .thumb folder stop creation
lborduca80_
Good morning, I recently bought nas542. I have the problem of the continuous generation of the .thumb folders, I would like to avoid. I have disabled the thumbnail creation feature for media files from myZyXELcloud but I have not fixed the problem. I tried to remove the .thumbs directories from windows 10 but not solve the problen, it seems that the nas recreate them. Can you help me?
Regards.
#NAS_May
Regards.
#NAS_May
@lborduca80_
Here you can refer the link below for disable myzyxelcloud thumbnail, then NAS542 will stop to create .thumb files and you can delete it.
https://homeforum.zyxel.com/discussion/comment/2046#Comment_2046
Hello, as I have already written, I had already done to disable the generation of .thumb folders but I notice that in the subdirectories these folders automatically regenerate a few seconds after I have removed them. Do you have any other suggestions about it?
Hi, that is weird..., I disable it in my NAS and delete the .thumb folder, but the folder would not be generate again.
You can through telnet with command " ps | grep zyxel" to check if the daemon is disable or not.
Here is screenshot for you.
Enable:
Disable:
Hello, I did some tests and I saw that apply "disabled the thumbnail creation feature for media files", restarting the nas542 and removing the .thumb directories directly from the terminal (shell) solves the problem. I hope it can help the community. Thank you for support.0
- 431 Beta Program
- 2.6K Nebula
- 164 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
