Zyxel NAS 540 with Seagate İronWolf 8GB
sinirli
sinirli Posts: 2 image  Freshman Member
edited May 2018 in Personal Cloud Storage
I recently purchased the NAS 540 to use it with my Seagate Ironwolf 8GB (ST8000VN0022) but the disk physically does not fit into the yellow plastic in the NAS.
There are 2 small nubs on the plastic that just don't have anywhere to go in the disk.
Is there a solution for this? Other than changing the NAS or disk I mean..
#NAS_May
  • Ijnrsi
    Ijnrsi Posts: 254 image  Master Member
    The only way I think is cut it out....
    Or you can put something under the HDD in the slot to make the HDD be possible to plug into the SATA interface, but this is really not a good option..
  • sinirli
    Thanks Ijnrsi, I think I will just buy another disk and sell this one
