Need P-660H-T1 v3s firmware
leofante
Hi, I need a "P-660H-T1 v3s" firmware.
I've already searched on the zyxel support site but for this modem there aren't any download.
#CPE_June
#CPE_June
Hi leofante,
What is firmware version of your device now?0 -
I don't know, the previous owner flashed a wrong firmware.
I can reprogram the flash chip directly0 -
Hi leofante,
May I know where you bought this device? How about status of this device? Can you login to device?
“the previous owner flashed a wrong firmware.I can reprogram the flash chip directly”. So it means that you change flash by yourself, but there is no fw image currently, right?
I didn't bought it, it was given to me hoping I can fix it, I think it was bought in a store several years ago.
I cannot login in the device via browser.
Using the serial connector on the board i get this:Bootbase Version: VTC_SPI_WR1.10 | 2010/06/23 09:32:52RAM: Size = 16384 KbytesDRAM POST: Testing: 16384KOKFound SPI Flash 2MiB Winbond W25Q16 at 0xbfc00000SPI Flash Quad EnableTurn off Quad ModeRAS Version: 3.40(TSC.1)Press any key to enter debug mode within 3 seconds...............Enter Debug ModeatOKathe======= Debug Command Listing =======AT just answer OKATHE print helpATBAx change baudrate. 1:38.4k, 2:19.2k, 3:9.6k 4:57.6k 5:115.2kATENx,(y) set BootExtension Debug Flag (y=password)ATSE show the seed of password generatorATRLx display the 32-bit value of address xATGO(x) run program at addr x or boot routerATGR boot routerATRTw,x,y(,z) RAM test level w, from address x to y (z iterations)ATSH dump manufacturer related data in ROMATTD download router configuration to PC via XMODEMATUR upload router firmware to flash ROMATLC upload router configuration file to flash ROMATXSx xmodem select: x=0: CRC mode(default); x=1: checksum modeATLD Upload Configuration File and Default ROM File to FlashATCD Convert Running ROM File to Default ROM File into FlashOKI've tried ATUR with fimware from similar models but without successStarting XMODEM upload (CRC mode)....CTotal 1284608 bytes received.Wrong product firmware!!Please upgrade the newest firmware version!!ERROR
as mentioned before I can also program the flash chip directly with a programmer.
The problem is that I've been unable to find the correct firmware for this device on any zyxel site
Hi leofante,
In order to provide you with a better assistance, we contacted you through private message to get more information, please check your message box.0 -
Hey,
The log seems come from internal serial port.
I am just curious how you can get the internal serial log?0
- 441 Beta Program
- 210 Nebula Ideas
- 539 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
