....contact you through private message:((((
elcapito
The Zyxel moderators takes questions out of the forum to "contact you through private message".
This will solve only one customers problems. This is not good!
I have the same problem, in the same country, on the same phone as Datarzan...in his message of June 6 2018.
I have no clue about the fix!
This is wrong way to use this community board!
There is an iOS app problem!!! It does not connect!
#Others_July
#Others_July
Hi elcapito,
May I know what is your product model?Can you share detail information about your problem?0
Hi elcapito,
May I know what is your product model?Can you share detail information about your problem?0 -
Hanamichi!
Thanks, but I am now in contact with moderator! Hopefully this will solve my "disconnected" problem. If not, I will give you the specifics! Thanks again, for taking time to help!
Elcapito1
- 588 USG FLEX H Series
- 476 News and Release
