AMG1302-T11C firmware update what new?
#CPE_July
Hi CAL18,
Your firmware version is V3.00(ABCG.12)C0, right ? You can check V3.00(ABCG.13)C0 release note from : https://www.zyxel.com/support/DownloadLandingSR.shtml?c=gb&l=en&kbid=M-02433&md=AMG1302-T11C#searchZyxelTab1
It describes what corrections we made in V3.00(ABCG.13)C0.
That right can I update it without losing settingsI'm having issue of low WiFi on the abcg. 12 firmware0
Hi CAL18,
You will not lose the setting by upgrade firmware via GUI : Maintenance -> Firmware Upgrade
Ok thanks this is safe to do on post office router right as it uses zyxel gui and not some custom post office gui
Can I upgrade the post office router it same model with the above firmware
Hi CAL18,
I suggest you can check with post office directly. Even you can use above fw version, but it might have some specific settings that must meet in post office environment. So it’s better to check first, otherwise, it’s possible to lost internet access after upgrading fw.
Hi CAL18,
Hi CAL18,
- 588 USG FLEX H Series
- 476 News and Release
