Forgot my login/password on the mobile app zCloud!
Flinta
Anyone can help how i can recover that?
Thx
#NAS_June
If the account is admin, that you can use HW reset button with 1 beep and release to reset the password back to "1234", but the acount is normal account, you can use admin to modify the password directly.0
Thank you for the answer ljnrsi..nut that is for the NAS login..not for the ZCLOUD APP!0
zCloud APP is using NAS's login password to access, so it can work for you.
Have you tried it before?0 -
does anyone know what the username and password should be when you first login to the zcloud app and it finds your device by IP and then it asks for username and password, I try the one that I use to login and it says invalid.0
As I know, need to login NAS firstly, set up the username and password, after that, you can login zcloud app with the username and password.
I'll suggest to use Zyxel drive app, it use Pcloud server account to login.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
