Using a wildcard SSL certificate for Zywall 1100's web interface
Hi all,
Is there a way to import an already-generated wildcard certificate into Zywall 1100 to serve as the SSL cert for its https interface? Everytime I try to import the cert, I get a response that the original CSR is not present. It was actually generated on a different machine and hence unavailable here.
Any clues on how to get it working?
You need to import the PKCS #12 format file (certificate with private key) into USG.
Then change the web settings of USG to use this certificate.
1.On USG GUI, go to Object > Certificate > My Certificate page. Click Import to import the file.
2.Go to System > WWW, under HTTPS section, change the Server Certificate to the new Import one.
5
5 -
Thanks @zyman2008 I did that, but right after I did it, the web interface became unavailable until I reverted back to the old (URL specific certificate).
Is there any thing else that is needed when the certificate has is wildcard?
Nevermind my last reply...
The first time, I generated a pkcs12 file with both the cert and CAcert bundled together.
After some thought, I imported the CA cert separately (the direct crt file I got from namecheap) and generated a pkcs12 with only the wild card crt file. This did the trick.
Thanks again to @zyman2008 for the advice.0
- 588 USG FLEX H Series
- 477 News and Release
