NAS540 import volume
tolyaasch
tolyaasch Posts: 10 image  Freshman Member
edited August 2018 in Personal Cloud Storage
Dear community, I want to put one HDD from my "master" NAS540 to my "backup" NAS540 but I don´t know how. I need all that data on HDD, don´t want to erase it. How can I do it? Please help me. Now I inserted HDD to "backup" NAS and see this:
#NAS_Aug
Best Answers
  • Ijnrsi
    Ijnrsi Posts: 254 image  Master Member
    What is your file system type for the HDD in master?
    Normally, if the HDD is basic then it should be detect and mount to backup NAS.
    Did you try reboot?
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    edited August 2018 Answer ✓
    You have 2 volumes with the same name. AFAIK that is just a label on the volume, but the firmware uses it to tag the volume.
    I *think* that if you edit one of the labels, and reboot the box, your problem will be solved.
    To find which file to edit you can execute (in an ssh shell)
    grep volume /i-data/????????/.system/name_label -i -H
    this will print the label files, followed by their content.
  • Ijnrsi
    Did you try reboot?
  • tolyaasch
    After reboot:
  • Mijzelf
  • tolyaasch
    Dear @Mijzelf and @Ijnrsi Thank you! After about 3 hours of gugling of "how to use putty" "dos commands in linux" and "how to edit file in linux" or "how to use vi" i finished it :dizzy: and WORKING!!! I think, this feature can be in UI to help BFUs like me to easily swap disks between NASes. Thank you all and have a nice day.
    Viktor
