NAS540 import volume
tolyaasch
Dear community, I want to put one HDD from my "master" NAS540 to my "backup" NAS540 but I don´t know how. I need all that data on HDD, don´t want to erase it. How can I do it? Please help me. Now I inserted HDD to "backup" NAS and see this:
#NAS_Aug
#NAS_Aug
Best Answers
What is your file system type for the HDD in master?
Normally, if the HDD is basic then it should be detect and mount to backup NAS.
Did you try reboot?0 -
You have 2 volumes with the same name. AFAIK that is just a label on the volume, but the firmware uses it to tag the volume.I *think* that if you edit one of the labels, and reboot the box, your problem will be solved.To find which file to edit you can execute (in an ssh shell)
grep volume /i-data/????????/.system/name_label -i -H
this will print the label files, followed by their content.
After reboot:
Dear @Mijzelf and @Ijnrsi Thank you! After about 3 hours of gugling of "how to use putty" "dos commands in linux" and "how to edit file in linux" or "how to use vi" i finished it
and WORKING!!! I think, this feature can be in UI to help BFUs like me to easily swap disks between NASes. Thank you all and have a nice day.
Viktor1
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
