Problems after firmware update NAS326 V5.21 AAZF.2
frarac78
Hello everyone, after the bad idea to update the firmware of my NAS326 from the perfect version 5.21 AAZF.1 to the AAZF.2 I can not move, delete and copy files from NAS to USB hard disk or internally at the nas as I have always done. I guess it's a problem with this version of the firmware ... do you know how to fix my problem or how to downgrade the firmware to the previous version that was fine?
#NAS_Aug
#NAS_Aug
If you login over ssh, and execute
echo 1 > /firmware/mnt/info/revision
you can downgrade by uploading an old firmwarefile in the webinterface.
I'm sorry, I'm not really practical about it. You could explain to me step by step? Thank you in advance!
Tx Mijzelf all ok thanks at your tips!!
Also -- you might want to see my Oct 3 post on this thread: https://homeforum.zyxel.com/discussion/1178/nas326-unable-copy-move-delete-folder-or-file-after-last-firmware-update#latest
pkas0
- 434 Beta Program
- 174 Nebula Ideas
- 417 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 269 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 87 Security Highlight
