Using Zyxel Multy X with ISP Modem/Router
Eeperman
Hi all
i have broadband with BT and use the standard BT Homehub. I have just purchased a Multy X to boost the WiFi coverage in my house and am a bit confused how to set it up with the Homehub. The hub does not allow bridge (modem only) mode so it has to stay acting as a router. Do I just plug in the Multy X into an Ethernet port and set up as normal? Or do I have to change any of the settings on the Multy? My understanding is that the Multy acts as a router also, but I believe that you can’t have two routers on the same network.
The alternative is is to try and get a simple modem out of BT, but I don’t think they hand those out any more.
Many thanks
#MultyX_Aug
Many thanks
#MultyX_Aug
@Eeperman,
It depends on your usage to choose Multy X as router mode or bridge mode.
1.) Multy X is router mode, you may need to put your original device under Multy X.
Internet---BT Homehub(Modem)<LAN>---<WAN>1st Multy X)))<WLAN>(((2nd Multy X
This setting have double NAT environment. Because BT Homehub and Multy X has different network segment. If the client device is connect to BT Homehub, it may not able to communicate with under Multy X client device.
2.) Multy X is bridge mode, you can keep your original device environment.Internet---BT Homehub(Modem)<LAN>---<WAN>1st Multy X)))<WLAN>(((2nd Multy XIn this case, it has the same network segment. All IP will assign from BT Homehub DHCP server.
After you have setup Multy X WiFi System, you can go to "Settings" > "Network Mode" to change Multy X as router mode or bridge mode.
Thank you Steven. I have set the system up and it seems to be working fine in NAT mode so I may just leave it alone!1
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
