Multy X MAC Address
MIBSWE
I just wanted to check that Multy X AC3000 advertises two MAC addresses for each frequency of 2.4GHz and 5GHz. I run InSSider on my MAC and it sees two MAC addresses for my 2.4GHz and 2 for my 5GHz. I'm assuming one is for devices to connect to and the other is the backend channel for the mesh devices to communicate. The MAC addresses are Zyxel as verified when I checked them on macvendors.com. Can you confirm?
#MultyX_Sep
#MultyX_Sep
How many Multy X nodes you have?
If you have two Multy X nodes, you should able to see 8 BSSID when you enable main WiFi and guest WiFi. Each Multy X node has 2 BSSID for main WiFi: 2.4GHz and 5GHz, 2 BSSID for guest WiFi: 2.4GHz and 5GHz.
For example:
Yes it did. Thank you. I just wanted to check as I have a system that tells me when it detects an intruder and displayed its MAC address. I have 2 nodes running both frequencies, but GUEST is disabled, so I can see 4 MAC addresses, 2 for each frequency.1
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
