NSA310 TDC to standard firmware
Alexey2008
Hello. I bought an NSA310 TDC Homedisk. I want to install the standard firmware NSA310 on it. The site nas-central.org does not open. Where can I get the files for the procedure of changing the firmware to the stock? #NAS_Oct_2018
@Alexey2008 : How are your scripting skills? The needed universal_usb_key_func.zip is archived by archive.org. Search this forum, somewhere I put a download link.
I do not have the force_flash anymore, but I still have the original flashing script. It needs to be adapted a bit (pull the device check, do something with filenames, redirect output to logfile). At the moment I have no time for that.
Do you check with TDC?
I think they should have the way to help user to change the TDC device to standard version.0 -
Good afternoon! Thank you very much for the answer. I have already figured out). Three days of study) Now installed stock version. I changed the identifier and flashed it through nsa310_recovery_usb.
@Alexey2008
Can you tell me how you did. I must also put an original zyxel firmware on tds nsa310. Thanks0 -
do enyone have the force_flash.zip0
does anyone cand write the steps to do that?0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
