Model VMG8825-B and iOS Multy Pro app
stefano_sb
Does the Multy Pro app work with VMG8825-B? I have tried but the app doesn't found the router :-( Thanks
#CPE_Oct_2018
#CPE_Oct_2018
Hi stefano_sb,
May I have your VMG8825 firmware version?
Please share your connect steps and what's the error message?
Hi AAAAL, thanks for your answer. VMG8825 firmware version is V5.13(ABLZ.0)b10_20180319. It's a custom version from Wind/Infostrada my telephone operator. When the MultyPro app starts it found the router but after few seconds it disappears... I have no error message :-(0
Any news? :-)0
With the new Android Multy Pro App version (1.0.5.181012) I can see my VMG8825-B but... which password I have to use to login???
Hi stefano_sb,
Password is the same as you login to GUI. If you didn't change default password, you can find it on back label of your device.0 -
Thanks for the answer.... I have changed the password.T he new password is ok using GUI (with user = admin) but it doesen't work from App (where there no way to insert the user...).0
Hi stefano_sb,
In order to provide you with a better assistance, we contacted you through private message to get more information, please check your message box.
I have the same problem too and the same router/firmware.
How it was solved this issue?
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
