ZYXEL 326 unmounted shares
jan_filipec
Hi, I was trying to mount a full hdd to my Zyxel 326 and when unmounting it, I accidentaly unmounted almost all the shares with umount -a. Now only admin and data shares work, the others I can not access and I also can not access the web gui, asi it always says my password is wrong. Anybody knows which partitions are mounted where by default so I can set it back?
Thanks a lot.
#NAS_Oct_2018
#NAS_Oct_2018
You can't mount them back, as you also unmounted some tmpfs filesystem, which are lost in cyberspace now. But you can simply reboot to get your mounts back.
Oh wow, did not expect that to be that easy. Thanks a lot.0
- 588 USG FLEX H Series
- 476 News and Release
