Hi, Question about NSA320
Leopoldyy2
it does not work properly.
it crashes every now and then.
each time you turn off the network, it reboots the names.
although I have already changed the batteries because I thought it was a battery fault.
but it turned out that it was not.
the second thing is that I can not run any crap
System Setting - Firmware/Packages
Package
Package Management
does it have any flash memory in addition to the memory of the frames ??
#NAS_Oct_2018
I forgot to add all the time saying that there is no memory
"This feature is not available for there is no volume. |
what is your firmware version?
Try reset the device?0 -
NSA320S_V4.75(AANV.2)C0
how to make a hard reset0
good uncle google has already told me how to do it about you can close the restart helped
Thank you for your help
- 588 USG FLEX H Series
- 477 News and Release
