NSA310s predefined shares without disk value
klcko001
klcko001 Posts: 7 image  Freshman Member
edited November 2018 in Personal Cloud Storage
Hello, I am not able to assigned predefined shares ( like "video")to a disk volume on ma NSA320s. I have tried factory reset, reinstall, ... nothing helps .... Because of this I can not copy any file to predefined shares. Predefined share path is without volume name. I can only create my own- user defined shares, but they are not stable enough. When NSA is restarted, user-defined shares changed their permission to private, and folders are not visible anymore. I have attached some pictures , Can you please help me ?
#NAS_Oct_2018
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    edited October 2018 Answer ✓
    drwxrwxrwx    1 root     root          2048 Jul 29  2013 sysvol
    That's your problem. It's a directory, while it should be a symlink.
    So execute
    <div>su</div><div><br></div><div>rm -rf /etc/zyxel/storage/sysvol</div><div><br></div><div>ln -s /i-data/abd50cdc /etc/zyxel/storage/sysvol</div><div><br></div><div>reboot<br></div>
  • Ijnrsi
    Ijnrsi Posts: 254 image  Master Member
    Is the HDD brand new?
    If yes, then I suggest you to recreate the volume and do again reset, because it seems the configuration is not matched your current HDD.
  • klcko001
    Helo, thank you for your answer. HDD is brand new / i have replaced the old broken one.I have tried: delete volume, recreate volume, run install again, .... but no succes. Does anybody have a hint fir me? Thank you.
  • Mijzelf
    Do you have shell access? You can use the Telnet backdoor for that. Then execute
    ls -l /etc/zyxel/storage/
    It should show something like
    admin@NAS520:/$ ls -l /etc/zyxel/storage/<br>-rw-rw-rw-&nbsp;&nbsp;&nbsp; 1 root&nbsp;&nbsp;&nbsp;&nbsp; root&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0 Sep 22 23:11 enable_nfs.flag<br>-rw-rw-rw-&nbsp;&nbsp;&nbsp; 1 root&nbsp;&nbsp;&nbsp;&nbsp; root&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 215 Aug&nbsp; 5 13:33 extuuid.table<br>-rw-r--r--&nbsp;&nbsp;&nbsp; 1 root&nbsp;&nbsp;&nbsp;&nbsp; root&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 6 Jun 17&nbsp; 2017 pwron.int<br>lrwxrwxrwx&nbsp;&nbsp;&nbsp; 1 root&nbsp;&nbsp;&nbsp;&nbsp; root&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 16 Sep 30&nbsp; 2016 sysvol -> /i-data/38aa86ff<br>
    Have a look at the symlink sysvol, which should point to your data volume. In my case this is /i-data/38aa86ff. In your case it will be something else, and have a look if that volume exists:
    ls /i-data/
  • klcko001
    -rw-rw-rw-    1 root     root             0 Oct 17 19:06 extuuid.table
    -rw-rw-rw-    1 root     root             0 Oct 31 20:05 mduuid.table
    -rw-rw-rw-    1 root     root             0 Dec 31  2016 usbcopy.table
    -rw-rw-rw-    1 root     root             0 Dec 31  2016 usbzync.table
  • klcko001
    /etc/zyxel/storage/sysvol $ ls /i-data/
    abd50cdc  md0
  • klcko001
    /etc/zyxel/storage/sysvol $ su
    BusyBox v1.17.2 (2017-06-08 10:52:17 CST) built-in shell (ash)
    Enter 'help' for a list of built-in commands.
    ~ # echo "Volume1" >/i-data/sysvol/.system/name_label
    sh: can't create /i-data/sysvol/.system/name_label: nonexistent directory
  • klcko001
    admin   music   photo   public  video
  • Mijzelf
    drwxrwxrwx&nbsp; &nbsp; 1 root&nbsp; &nbsp; &nbsp;root&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 2048 Jul 29&nbsp; 2013 sysvol
    So execute
