NSA310s predefined shares without disk value
klcko001
Hello, I am not able to assigned predefined shares ( like "video")to a disk volume on ma NSA320s. I have tried factory reset, reinstall, ... nothing helps .... Because of this I can not copy any file to predefined shares. Predefined share path is without volume name. I can only create my own- user defined shares, but they are not stable enough. When NSA is restarted, user-defined shares changed their permission to private, and folders are not visible anymore. I have attached some pictures , Can you please help me ?
#NAS_Oct_2018
drwxrwxrwx 1 root root 2048 Jul 29 2013 sysvolThat's your problem. It's a directory, while it should be a symlink.So execute<div>su</div><div><br></div><div>rm -rf /etc/zyxel/storage/sysvol</div><div><br></div><div>ln -s /i-data/abd50cdc /etc/zyxel/storage/sysvol</div><div><br></div><div>reboot<br></div>
Is the HDD brand new?
If yes, then I suggest you to recreate the volume and do again reset, because it seems the configuration is not matched your current HDD.
Helo, thank you for your answer. HDD is brand new / i have replaced the old broken one.I have tried: delete volume, recreate volume, run install again, .... but no succes. Does anybody have a hint fir me? Thank you.0
Do you have shell access? You can use the Telnet backdoor for that. Then execute
ls -l /etc/zyxel/storage/
It should show something likeadmin@NAS520:/$ ls -l /etc/zyxel/storage/<br>-rw-rw-rw- 1 root root 0 Sep 22 23:11 enable_nfs.flag<br>-rw-rw-rw- 1 root root 215 Aug 5 13:33 extuuid.table<br>-rw-r--r-- 1 root root 6 Jun 17 2017 pwron.int<br>lrwxrwxrwx 1 root root 16 Sep 30 2016 sysvol -> /i-data/38aa86ff<br>
Have a look at the symlink sysvol, which should point to your data volume. In my case this is /i-data/38aa86ff. In your case it will be something else, and have a look if that volume exists:ls /i-data/
-rw-rw-rw- 1 root root 0 Oct 17 19:06 extuuid.table-rw-rw-rw- 1 root root 0 Oct 31 20:05 mduuid.tabledrwxrwxrwx 1 root root 2048 Jul 29 2013 sysvol-rw-rw-rw- 1 root root 0 Dec 31 2016 usbcopy.table-rw-rw-rw- 1 root root 0 Dec 31 2016 usbzync.table~ $0
/etc/zyxel/storage/sysvol $ ls /i-data/abd50cdc md0/etc/zyxel/storage/sysvol $0
/etc/zyxel/storage/sysvol $ su
BusyBox v1.17.2 (2017-06-08 10:52:17 CST) built-in shell (ash)Enter 'help' for a list of built-in commands.~ # echo "Volume1" >/i-data/sysvol/.system/name_labelsh: can't create /i-data/sysvol/.system/name_label: nonexistent directory~ #0 -
/etc/zyxel/storage/sysvol $ lsadmin music photo public video/etc/zyxel/storage/sysvol $0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
