entware on NSA320
canute
I accidentally uninstalled Entware on my NSA320.
I'm not able to reinstall it through the Web Admin packages page (That page doesn't Retrieve any new list from internet nor does install change anything in /opt directory)
Does anyone know how to fix this?
#NAS_Oct_2018
But when I try to install Entware(It completes to 100%), I don't see anything installed in /opt. That directory is still empty.Can you have a look at the logs in /usr/local/zy-pkgs/opt/var/log?Is there any way for me to install the Entware package from command line?Theoretically yes. You can follow the script in /usr/local/zy-pkgs/etc/init.d/Entware-ng. But it's not straightforward, and get it started on boot isn't simple either.
I tried to use this as the new Repository link and followed instructions from https://web.archive.org/web/20180324144301/http://zyxel.nas-central.org/wiki/3rd_party_zypkgs. I see the new merged list obtained alright.
Is there any way for me to install the Entware package from command line?0 -
The log file at /usr/local/zy-pkgs/opt/var/log eventually worked. I found that my DNS was pointed to some bad address. Once I fixed that and some permissioning issues in /opt folder, I was able to install Entware throught the Web admin page.0
- 441 Beta Program
- 293 Service & License
