IPV6 VMG1312-B10D
How can i fix this
#CPE_Oct_2018
Hi RichTea,
VMG1312 do not support this feature and cannot achieve this via CLI or other ways.
Thank you.
Hi RichTea,
What’s your VMG1312-B10D firmware version?
You cannot find “Prefix Delegation” in GUI Network Setting -> Broadband -> WAN Interface?
If change the LAN IPv6 Address Setup to “Static”, LAN client can have the IPv6 prefix from VMG or not?
I have updated FW to latest version i could find :V5.13(AAXA.7)C0
This is the Lan setup page
Hi RichTea,
May I know your LAN client under the VMG can use the IPv6 connection to the Internet without a problem?
Change LAN side IPv6 Prefix Setup to Static, you can find the prefix parameter in the packets or not?
Hi Sorry for the slow reply!...I have now set my Lan to a static prefix I gave it a static prefix something like "aaaa:bbbb:cccc:17::/64"The router on my Lan now gets an address in that range but still with "(status-code NoPrefixAvail) " in the "dhcp6 advertise" packetMy Lan Client is an "OpenWrt 18.06.1" device here is the tcp dump...
14:38:49.802312 IP6 (flowlabel 0xa3eee, hlim 1, next-header UDP (17) payload length: 120) fe80::eeee:ffff:bbbb:9119.546 > ff02::1:2.547: [udp sum ok] dhcp6 solicit
(xid=b2422a (elapsed-time 0) (option-request SIP-servers-domain SIP-servers-address DNS-server DNS-search-list SNTP-servers NTP-server AFTR-Name opt_67 opt_82 opt_83 opt_94 opt_95 opt_96 server-unicast)
(client-ID hwaddr type 1 aabbccddeeff) (reconfigure-accept) (Client-FQDN) (IA_NA IAID:1 T1:0 T2:0) (IA_PD IAID:1 T1:0 T2:0))
14:38:49.804597 IP6 (hlim 64, next-header UDP (17) payload length: 110) fe80::bbbb:aaaa:eeee:7180.58886 > fe80::eeee:ffff:bbbb:9119.546: [udp sum ok] dhcp6 advertise
(xid=b2422a (client-ID hwaddr type 1 aabbccddeeff) (server-ID hwaddr type 1 bbbbaaaaeeee) (IA_NA IAID:1 T1:43200 T2:69120 (IA_ADDR aaaa:bbbb:cccc:17::2 pltime:86400 vltime:86400))
(status-code NoPrefixAvail) (DNS-server cache01.dns.uk))
14:38:50.955024 IP6 (flowlabel 0xa3eee, hlim 1, next-header UDP (17) payload length: 146) fe80::eeee:ffff:bbbb:9119.546 > ff02::1:2.547: [udp sum ok] dhcp6 request
(xid=bad983 (elapsed-time 0) (option-request SIP-servers-domain SIP-servers-address DNS-server DNS-search-list SNTP-servers NTP-server AFTR-Name opt_67 opt_82 opt_83 opt_94 opt_95 opt_96 server-unicast)
(client-ID hwaddr type 1 aabbccddeeff) (server-ID hwaddr type 1 bbbbaaaaeeee) (reconfigure-accept) (Client-FQDN) (IA_NA IAID:1 T1:0 T2:0 (IA_ADDR aaaa:bbbb:cccc:17::2 pltime:86400 vltime:86400)))
14:38:50.957511 IP6 (hlim 64, next-header UDP (17) payload length: 104) fe80::bbbb:aaaa:eeee:7180.58886 > fe80::eeee:ffff:bbbb:9119.546: [udp sum ok] dhcp6 reply
(xid=bad983 (client-ID hwaddr type 1 aabbccddeeff) (server-ID hwaddr type 1 bbbbaaaaeeee) (IA_NA IAID:1 T1:43200 T2:69120 (IA_ADDR aaaa:bbbb:cccc:17::2 pltime:86400 vltime:86400)) (DNS-server cache01.dns.uk))
Hi RichTea,
VMG1312 will not create an IA_PD for its downstream network interfaces, that’s why you get the status-code NoPrefixAvail. The IPv6 prefix setting in GUI is for the LAN client can use this prefix to have own v6 address.
I think you can have a look that VMG will have an Advertisement for “Prefix Information” take along "aaaa:bbbb:cccc:17::/64".
Hi AAAAL,Thank you for all your answers so far...So is there no way to get the VMG1312 to hand out Prefixes, maybe something in the CLI?
Hi RichTea,
Thank you.
Hi @RichTea
My VMG1312-B10D running 5.13(AAXA.10)C0 firmware has a way to give out a Static IPv6 prefix as well as setting up the IPv6 link local addresses, IPv6 global identifier type, as well as other settings related to DHCPv6 such as Router Announcement, see below screenshot.
Kind regards,
Tony
- 588 USG FLEX H Series
- 476 News and Release
