NBG-419N v2 router not working when WIFI button is ON
Cristal
Hey guys
I got this router from Zyxel, model number NBG-419N v2, im using it now for several years.
Today my internet was not working, not the WIFI and not the laptop that is conected to a LAN port.
All the leds(WAN and LAN) where off and just blinking from time to time(several seconds intervals)
I tried to enter the routers set up menu but i could not! I tried everything to make it work(powered it off and on) and somehow i thought to turn off the WIFI button on the back of the router.
All of a sudden the WAN and LAN port leds where on and the interned started to work again on my laptop.
Now i could even enter the setup menu, i did a factory reset from the button on the back of the router, i did the set up again entering all my ISP data but when i turn on the WIFI button again everything is crashing and not working.
When WIFI button is on i have no internet via WIFI and nor via LAN cable.What could be wrong? Can someone help me?
Thanks!
#Router_Nov_2018
Thanks!
#Router_Nov_2018
Can you provide your network topology?
What is the firmware version of your NBG-419N v2?
Please try to enable HW WiFi Button and do HW reset, then NBG-419N v2 is only connected a laptop via LAN, is the problem still existed?
Hey
Thanks for the reply. Here is the firmware of my router:V1.00(AACU.7)C0
I dont really know what you mean by network topology. I did all the steps, i factory reset the router multiple times. It seems that is something related to the router, even if i have the internet cable out of the rooter when i pus the WIFI button on everything is going awkward, i cant even access the routers setup page via the routers IP. Nothing is working when i push on that button, like the router is dead, leds are blinking from time to time chaotically.0 -
We have contacted you via private message. Please kindly check your message box.0
Hello Steven, i replied to the PM, thanks!1
I need help, also problem
Cristal said:Hey guys
Thanks!
#Router_Nov_2018
I tried resetting it to factory defaults, but to no avail. It acts the same after the reset. I can access the router's menu and use the Internet only when the WiFi button is off. And if I turn the WiFi button on - the router is completely useless.
Firmware version: V1.00(AACU.7)C0
Downgrading to V1.00(AACU.5)C0 doesn't help. I tried.
Is there a solution? Can somebody help me please?0 -
It looks like it is hardware issue, and this model is quite old.Maybe you can consider for the new model.1
Hello @zelenimarsovac
I agree with @Hill that you might want to consider a newer device. The latest firmware release for your NBG-419Nv2 was in 2015.
Looking at the release note from 2015, see ftp://ftp2.zyxel.com/NBG-419N_v2/firmware/NBG-419Nv2_V1.00(AACU.7)C0_ReleaseNote.pdf , there was a bug fix done for poor WiFi performance but that might not be your issue.
Kind regards,
Tony1 -
Yes, I think it is probably a hardware issue, since nothing I tried helped. I was afraid of that. It served me well. RIP my old two-antenna friend. Thank you all for your advices.1
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
