Multy App not compatible
Mosvold
Mosvold Posts: 6
Second Anniversary
edited December 2018 in Multy WiFi System
I just bought a pair of multy x. But I cannot install the app on my Huawei P20. It say my device is not compatible. When i use "https://play.google.com/store/apps/details?id=com.zyxel.multyx&rdid=com.zyxel.multyx" both my phone and tablet is gray.
Please advice.
#MultyX_Dec_2018
  • Zyxel_Steven
    Zyxel_Steven Posts: 246  Zyxel Employee
    @Mosvold,
    In order to provide you with a better assistance, we have contacted you via private message. Please kindly check your message box.
  • Dexter
    Dexter Posts: 108
    Hi Mosvold,
    Multy X is only supported on mobile phone, not supported on tablet.
    https://homeforum.zyxel.com/discussion/150/what-are-the-required-android-and-ios-versions-for-multy-app/p1?new=1
    Can you provide some screenshot of your problem on Huawei P20?
    And what is the Android version?
  • Mosvold
    Mosvold Posts: 6
    Second Anniversary
    This is my phone:
    I cannot find the app when I search in Google Play, But only when I search google..
