VMG3925-B10B AAVF.11log settings
Tower
Tower Posts: 5  Freshman Member
edited December 2018 in Smart Home Product
How to change log settings?
The internal log is empty.
#CPE_Dec_2018
  • Tower
    Thank you all.
    'Log settings" was disabled in the ISP version of firmware. It has been fixed now.w
  • AAAAL
    AAAAL Posts: 125  Ally Member
    Hi Tower,
    Can you describe which log would you like to have?
    We can select log type on GUI: Maintenance -> log setting
    Check VMG log event on GUI: System Monitor -> log
