The ports at the rear seem dead?
Indigo_Ian1
Indigo_Ian1 Posts: 7  Freshman Member
edited December 2018 in Multy WiFi System
I am trying to connect a set of Sonos speakers and even with direct cable they can't be seen by the router.
I have looked at the settings on the router and the Port forwarding is Active, UPnP is Active but DMZ is not.
Is this correct as I don't know what any of these mean?
#MultyX_Dec_2018
  • Hill
    Hill Posts: 156
    May I know your ZYXEL product's model name and firmware version?
  • Indigo_Ian1
    Hi Multy X, Firmware V2.10(ABKJ.4)C0
  • Indigo_Ian1
    WSQ50 pack of 2
  • Indigo_Ian1
    Would having spaces in the naming of the router be causing a problem?
  • Hill
    Hill Posts: 156
    Can you share the model name of Sonos speaker?
    And what is your network topology?
    Do you mean when you're directly connected Sonos speaker to Mutly X via Ethernet cable, but the Multy App device list does not see it? Can Sonos speaker works?
  • Indigo_Ian1
    They are Sonos Play 1. We have two routers covering the two floors of the house. There are only 2 Sonos speakers in the adjacent room. But I have connected the Sonos directly to the rear of the router to alter the WiFi settings of the Sonos but it cant see the speaker.
    The speakers work fine on the old WiFi router settings.
  • Indigo_Ian1
    The perts at the rear seem dead, there are no lights indicating data is moving,
  • Indigo_Ian1
    Just connected a laptop and the ports are working
  • Zyxel_Steven
    Zyxel_Steven Posts: 246  Zyxel Employee
    @Indigo_Ian1,
    In order to provide you with a better assistance, we have contacted you via private message. Please kindly check your message box.
