transmission is missing
aksimoN
NAS326 after uninstall, I can't find in app center transmission to install. It isn't in all aplications list.
ps. how to install zpkg package?
#NAS_Dec_2018
#NAS_Dec_2018
Do you check your MetaRepository setting which allow to download Zyxel package?
It is my guess, if you reset to default, then you may need to remove web_prefix and retreive list to download and install transmission and reinstall the MetaRepository package again.
NAS326 has to create the volume and make sure NAS326 can access to Internet (you can go configurate > TCP/IP > Diagnost to ping check).
Then open App center to reflesh the list.
I did it. Diagnostic ping success. Downloading list of apps success but still no transmission on that list..
ps. I'm after factory reset and still have this problem
I put some '#' in other lines which I had in my MetaRepository and it woked.
Tnx a lot1
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
