Nas326 transmission config
pikehunter
pikehunter Posts: 6 image  Freshman Member
edited December 2018 in Personal Cloud Storage
Hello
Transmission saves the downloaded files in the admin folder.
There is a wish to adjust preservation in the new, separate folder, for example share. How to make it?
#NAS_Dec_2018
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    You should only edit the settings.json file with transmission disabled.
  • pikehunter
    I founded /i-data/.../.PKG/Transmission/.../config/settings.json , but after enable/disable transmission my chages are lost.
  • Mijzelf
  • Bongiozzo
    Bongiozzo Posts: 1 image  Freshman Member
    Make remote call periodically
    transmission-remote nas -w "/i-data/470f7598/video"
    it works for me.
