RAID 5 with 4 HDD one Failed how to reassamble the RAID .. not possible unter the GUI
T3sticle
Raid was degraded
swapped Disk fataly it was nr 4 not one
so i got a raid system on 3 disk but it was only recognised as a HOT Spare
how to access the data ?
Best regards
Bernd
#NAS_Dec_2018
You can also spent that 50 hours to think about a backup strategy. This episode has shown that data is fragile.
Are you saying that you by accident replaced the wrong disk? Have you already tried to put back that disk?
yes.. but my big fault was i didnt switch off before swapping cause i was afraid if i shut down everything is gone.
so i put it back just 5 seconds after pulling
so i know in fact all data is still avaiable on the 3 remanig disks but i have no clue how to tell that the Zyxel NAS
i think i have to do this with command lines but no idea how to tell
ok this is a raid 5 disk one fault
Disk 2 3 and 4 inserted try to find my data
Can you login over ssh, and post the results of
<div>cat /proc/mdstat</div><div><br></div><div>su</div><div><br></div><div>mdadm --examine /dev/sd[abcd]3</div>
BusyBox v1.19.4 (2017-05-26 16:43:23 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
/ $ cat /proc/mdstat
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md3 : active raid1 sda3[0]
1949383488 blocks super 1.2 [1/1] [U]
md2 : inactive sdb3[1](S) sdd3[3](S) sdc3[2](S)
5848151040 blocks super 1.2
md1 : active raid1 sda2[5] sdd2[4] sdb2[1] sdc2[2]
1998784 blocks super 1.2 [4/4] [UUUU]
md0 : active raid1 sda1[5] sdd1[4] sdb1[1] sdc1[2]
1997760 blocks super 1.2 [4/4] [UUUU]
unused devices: <none>
/ $ su
Password:
~ # mdadm --examine /dev/sd[abcd]3
/dev/sda3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Array UUID : cf843cce:ce996d42:6be461f6:adf6d3bb
Name : NAS540:3 (local to host NAS540)
Creation Time : Fri Dec 28 00:24:12 2018
Raid Level : raid1
Raid Devices : 1
Avail Dev Size : 3898767360 (1859.08 GiB 1996.17 GB)
Array Size : 1949383488 (1859.08 GiB 1996.17 GB)
Used Dev Size : 3898766976 (1859.08 GiB 1996.17 GB)
Data Offset : 262144 sectors
Super Offset : 8 sectors
State : clean
Device UUID : 1648013d:cb55855c:08ec1079:5531cc78
Update Time : Sun Dec 30 10:38:10 2018
Checksum : e8d25565 - correct
Events : 2
Device Role : Active device 0
Array State : A ('A' == active, '.' == missing)
/dev/sdb3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Array UUID : 07888a97:8a8267a6:12f71d42:dc23a5fd
Name : NAS540:2 (local to host NAS540)
Creation Time : Sun Aug 30 17:00:06 2015
Raid Level : raid5
Raid Devices : 4
Array Size : 5848150464 (5577.23 GiB 5988.51 GB)
State : clean
Device UUID : 9345f5fb:81ba7898:03dde380:08fbce0f
Update Time : Thu Dec 27 22:09:46 2018
Checksum : 36270b14 - correct
Events : 905
Layout : left-symmetric
Chunk Size : 64K
Device Role : Active device 1
Array State : .AAA ('A' == active, '.' == missing)
/dev/sdc3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid5
Raid Devices : 4
State : clean
Device UUID : 813341e2:bfc0a5ea:ef0c8ef4:c322dc04
A part is missing. The whole raid header of sdd, and a part of sdc.You have a single disk raid1 volume on sda, created at Fri Dec 28 00:24:12 2018, and a 4 disk raid5 array on sd[bcd], created on Sun Aug 30 17:00:06 2015. The array on sda is alive and kicking, the array on sd[bcd] is not assembled, because all members are marked 'spare'.So far it's not clear to me why (except for the root cause, pulling an active disk from an already degraded array) as the only visible array status from sdb isArray State : .AAA ('A' == active, '.' == missing)So according to this member the array should assemble from the 3 remaining disks. I think at least one of the other members will show another array state, as it's not assembled.According to /proc/mdstat the member 'roles' are neatly in order:md2 : inactive sdb3[1](S) sdd3[3](S) sdc3[2](S)role 1 for sdb, 2 for sdc and 3 for sdd. For sdb that fits with the output of mdadm:Device Role : Active device 1Alas I can't see that for sd[cd].Assuming that the roles in the headers concur with those in /proc/mdstat, you can re-create the array using the same settings as in 2015:
su
mdadm --stop /dev/md2
mdadm --create --assume-clean --level=5 --raid-devices=4 --metadata=1.2 --chunk=64K --layout=left-symmetric /dev/md2 missing /dev/sdb3 /dev/sdc3 /dev/sdd3Some settings are the defaults, according to https://linux.die.net/man/8/mdadm, but I just add them for safety and completeness.
Here --assume-clean tells mdadm the partitions contain a valid array, and the 'missing' keyword tells that the device with role '0' is missing. The roles 0 - 3 are assigned in the order in which you specify the partitions here.
The sequence of the other arguments is important for mdadm, and I don't know if this is the right sequence. Fortunately it will tell you if it's wrong, and it will also tell what should be right.
wow.. thx.. thats a lot of information...im german an my english is far from understanding everything..yes the disk one in raid1 as "only" member was inserted to reasamble the raid 5 of the 3 other disks.with the command line in yellowi should be able to recreate the raid 5 to access the data ?0
Thx for your help...but there seems some problems
~ # mdadm --stop /dev/md2
mdadm: stopped /dev/md2
~ # mdadm --create --assume-clean --level=5 --raid-devices=4 --metadata=1.2 --c
cat /proc/mdstat
mdadm: You have listed more devices (5) than are in the array(4)!
/dev/sda3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid1
Raid Devices : 1
State : clean
Update Time : Sun Dec 30 15:35:05 2018
Checksum : e8d29afc - correct
Events : 2
/dev/sdb3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid5
Raid Devices : 4
State : clean
Events : 905
Chunk Size : 64K
/dev/sdc3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid5
Raid Devices : 4
State : clean
Checksum : d7525769 - correct
Events : 905
Chunk Size : 64K
Device Role : Active device 2
Array State : .AA. ('A' == active, '.' == missing)
/dev/sdd3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid5
Raid Devices : 4
State : clean
Device UUID : 8e466416:80304d4c:3834cf56:3ce879c1
Update Time : Thu Dec 27 22:07:06 2018
Checksum : 8c00c5d8 - correct
Events : 905
Chunk Size : 64K
Device Role : Active device 3
~ # BusyBox v1.19.4 (2017-05-26 16:43:23 CST) built-in shell (ash)
sh: syntax error: unexpected "("
~ # Enter 'help' for a list of built-in commands.
sh: Enter: not found
~ # ~ # mdadm --stop /dev/md2
sh: /root: Permission denied
~ # mdadm: stopped /dev/md2
sh: mdadm:: not found
~ # ~ # mdadm --create --assume-clean --level=5 --raid-devices=4 --metadata=1.2
--c
~ # hunk=64K --layout=left-symmetric /dev/md2 missing /dev/sdb3 /dev/sdc3 /dev/
sdd3
sh: --layout=left-symmetric: not found
~ # cat /proc/mdstat
~ # mdadm: You have listed more devices (5) than are in the array(4)!
~ # ~ # mdadm --examine /dev/sd[abcd]3
~ # /dev/sda3:
sh: /dev/sda3:: not found
~ # Magic : a92b4efc
sh: Magic: not found
~ # Version : 1.2
sh: Version: not found
~ # Feature Map : 0x0
sh: Feature: not found
~ # Array UUID : cf843cce:ce996d42:6be461f6:adf6d3bb
sh: Array: not found
~ # Name : NAS540:3 (local to host NAS540)
~ # Creation Time : Fri Dec 28 00:24:12 2018
sh: Creation: not found
~ # Raid Level : raid1
sh: Raid: not found
~ # Raid Devices : 1
sh: Raid: not found
~ # Avail Dev Size : 3898767360 (1859.08 GiB 1996.17 GB)
~ # Array Size : 1949383488 (1859.08 GiB 1996.17 GB)
~ # Used Dev Size : 3898766976 (1859.08 GiB 1996.17 GB)
~ # Data Offset : 262144 sectors
sh: Data: not found
~ # Super Offset : 8 sectors
sh: Super: not found
~ # State : clean
sh: State: not found
~ # Device UUID : 1648013d:cb55855c:08ec1079:5531cc78
sh: Device: not found
~ # Update Time : Sun Dec 30 15:35:05 2018
sh: Update: not found
~ # Checksum : e8d29afc - correct
sh: Checksum: not found
~ # Events : 2
sh: Events: not found
~ # Device Role : Active device 0
~ # Array State : A ('A' == active, '.' == missing)
~ # /dev/sdb3:
sh: /dev/sdb3:: not found
~ # Version : 1.2
~ # Array UUID : 07888a97:8a8267a6:12f71d42:dc23a5fd
~ # Name : NAS540:2 (local to host NAS540)
~ # Creation Time : Sun Aug 30 17:00:06 2015
~ # Raid Level : raid5
sh: Raid: not found
~ # Raid Devices : 4
sh: Raid: not found
~ # Array Size : 5848150464 (5577.23 GiB 5988.51 GB)
sh: Data: not found
~ # State : clean
~ # Device UUID : 9345f5fb:81ba7898:03dde380:08fbce0f
~ # Update Time : Thu Dec 27 22:09:46 2018
~ # Checksum : 36270b14 - correct
~ # Events : 905
~ # Layout : left-symmetric
sh: Layout: not found
~ # Chunk Size : 64K
sh: Chunk: not found
~ # Device Role : Active device 1
~ # Array State : .AAA ('A' == active, '.' == missing)
~ # /dev/sdc3:
sh: /dev/sdc3:: not found
~ # Version : 1.2
sh: Raid: not found
sh: Raid: not found
sh: Data: not found
~ # State : clean
~ # Device UUID : 813341e2:bfc0a5ea:ef0c8ef4:c322dc04
~ # Checksum : d7525769 - correct
~ # Events : 905
~ # Device Role : Active device 2
~ # Array State : .AA. ('A' == active, '.' == missing)
~ # /dev/sdd3:
sh: /dev/sdd3:: not found
~ # Version : 1.2
sh: Raid: not found
sh: Raid: not found
sh: Data: not found
~ # State : clean
~ # Device UUID : 8e466416:80304d4c:3834cf56:3ce879c1
~ # Update Time : Thu Dec 27 22:07:06 2018
~ # Checksum : 8c00c5d8 - correct
~ # Events : 905
~ # Device Role : Active device 3
~ # ~ # BusyBox v1.19.4 (2017-05-26 16:43:23 CST) built-in shell (ash)
~ # sh: syntax error: unexpected "("
sh: sh:: not found
~ # ~ # Enter 'help' for a list of built-in commands.
~ # sh: Enter: not found
sh: sh:: not found
~ # ~ # ~ # mdadm --stop /dev/md2
~ # sh: /root: Permission denied
sh: sh:: not found
~ # ~ # mdadm: stopped /dev/md2
~ # sh: mdadm:: not found
sh: sh:: not found
~ # ~ # ~ # mdadm --create --assume-clean --level=5 --raid-devices=4 --metadata
=1.2
~ # --c
sh: --c: not found
sh: sh:: not found
~ # ~ # hunk=64K --layout=left-symmetric /dev/md2 missing /dev/sdb3 /dev/sdc3 /
dev/
~ # sdd3
sh: sdd3: not found
~ # sh: --layout=left-symmetric: not found
sh: sh:: not found
~ # ~ # cat /proc/mdstat
~ # Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
sh: Personalities: not found
~ # md3 : active raid1 sda3[0]
sh: md3: not found
~ # 1949383488 blocks super 1.2 [1/1] [U]
sh: 1949383488: not found
~ # md1 : active raid1 sda2[5] sdd2[4] sdb2[1] sdc2[2]
sh: md1: not found
~ # 1998784 blocks super 1.2 [4/4] [UUUU]
sh: 1998784: not found
~ # md0 : active raid1 sda1[5] sdd1[4] sdb1[1] sdc1[2]
sh: md0: not found
~ # 1997760 blocks super 1.2 [4/4] [UUUU]
sh: 1997760: not found
~ # unused devices: <none>
sh: syntax error: unexpected newline
~ # ~ # mdadm: You have listed more devices (5) than are in the array(4)!
sh: sh:: not found
~ # ~ # ~ # mdadm --examine /dev/sd[abcd]3
sh: sh:: not found
~ # ~ # /dev/sda3:
~ # sh: /dev/sda3:: not found
sh: sh:: not found
~ # ~ # Magic : a92b4efc
~ # sh: Magic: not found
sh: sh:: not found
~ # ~ # Version : 1.2
~ # sh: Version: not found
sh: sh:: not found
~ # ~ # Feature Map : 0x0
~ # sh: Feature: not found
sh: sh:: not found
~ # ~ # Array UUID : cf843cce:ce996d42:6be461f6:adf6d3bb
~ # sh: Array: not found
sh: sh:: not found
~ # ~ # Name : NAS540:3 (local to host NAS540)
sh: sh:: not found
~ # ~ # Creation Time : Fri Dec 28 00:24:12 2018
~ # sh: Creation: not found
sh: sh:: not found
~ # ~ # Raid Level : raid1
~ # sh: Raid: not found
sh: sh:: not found
~ # ~ # Raid Devices : 1
sh: sh:: not found
~ # ~ # Avail Dev Size : 3898767360 (1859.08 GiB 1996.17 GB)
sh: sh:: not found
~ # ~ # Array Size : 1949383488 (1859.08 GiB 1996.17 GB)
sh: sh:: not found
~ # ~ # Used Dev Size : 3898766976 (1859.08 GiB 1996.17 GB)
sh: sh:: not found
~ # ~ # Data Offset : 262144 sectors
~ # sh: Data: not found
sh: sh:: not found
~ # ~ # Super Offset : 8 sectors
~ # sh: Super: not found
sh: sh:: not found
~ # ~ # State : clean
~ # sh: State: not found
sh: sh:: not found
~ # ~ # Device UUID : 1648013d:cb55855c:08ec1079:5531cc78
~ # sh: Device: not found
sh: sh:: not found
~ # ~ # Update Time : Sun Dec 30 15:35:05 2018
~ # sh: Update: not found
sh: sh:: not found
~ # ~ # Checksum : e8d29afc - correct
~ # sh: Checksum: not found
sh: sh:: not found
~ # ~ # Events : 2
~ # sh: Events: not found
sh: sh:: not found
~ # ~ # Device Role : Active device 0
sh: sh:: not found
~ # ~ # Array State : A ('A' == active, '.' == missing)
sh: sh:: not found
~ # ~ # /dev/sdb3:
~ # sh: /dev/sdb3:: not found
sh: sh:: not found
sh: sh:: not found
sh: sh:: not found
sh: sh:: not found
~ # ~ # Array UUID : 07888a97:8a8267a6:12f71d42:dc23a5fd
sh: sh:: not found
~ # ~ # Name : NAS540:2 (local to host NAS540)
sh: sh:: not found
~ # ~ # Creation Time : Sun Aug 30 17:00:06 2015
sh: sh:: not found
~ # ~ # Raid Level : raid5
sh: sh:: not found
~ # ~ # Raid Devices : 4
sh: sh:: not found
sh: sh:: not found
~ # ~ # Array Size : 5848150464 (5577.23 GiB 5988.51 GB)
sh: sh:: not found
sh: sh:: not found
sh: sh:: not found
sh: sh:: not found
sh: sh:: not found
~ # ~ # Device UUID : 9345f5fb:81ba7898:03dde380:08fbce0f
sh: sh:: not found
~ # ~ # Update Time : Thu Dec 27 22:09:46 2018
sh: sh:: not found
~ # ~ # Checksum : 36270b14 - correct
sh: sh:: not found
~ # ~ # Events : 905
sh: sh:: not found
~ # ~ # Layout : left-symmetric
~ # sh: Layout: not found
sh: sh:: not found
~ # ~ # Chunk Size : 64K
~ # sh: Chunk: not found
sh: sh:: not found
~ # ~ # Device Role : Active device 1
sh: sh:: not found
~ # ~ # Array State : .AAA ('A' == active, '.' == missing)
sh: sh:: not found
~ # ~ # /dev/sdc3:
~ # sh: /dev/sdc3:: not found
sh: sh:: not found
sh: sh:: not found
sh: sh:: not found
sh: sh:: not found
sh: sh:: not found
sh: sh:: not found
~ # ~ # Creation T
sh: sh:: not found
sh: sh:: not found
~ # ~ # Ra
sh: sh:: not found
sh: sh:: not found
sh: sh:: not found
~ # sh:
sh: sh:: not found
sh: sh:: not found
sh: sh:: not found
~ # sh:
sh: sh:: not found
~ # ~ # Device UUID : 813341e2:bfc0a5e
sh: sh:: not found
sh: sh:: not found
sh: sh:: not found
sh: sh:: not found
~ # ~ # Layo
sh: sh:: not found
~ # ~ # Device Role : Active device 2
~ # sh: De
sh: sh:: not found
sh: sh:: not found
~ # ~ # /dev/sdd3:
~ # sh
~ # sh: Magic: n
sh: sh:: not found
sh: sh:: not found
sh: sh:: not found
~ # ~ # Array UUID
sh: sh:: not found
sh: sh:: not found
sh: sh:: not found
~ # sh: Raid: not
sh: sh:: not found
~ # s
sh: s: not found
sh: sh:: not found
sh: sh:: not found
sh: sh:: not found
sh: sh:: not found
sh: sh:: not found
sh: sh:: not found
sh: sh:: not found
sh: sh:: not found
~ # ~ # Checksum : 8c
sh: sh:: not found
~ # s
sh: s: not found
~ # ~ # La
sh: sh:: not found
sh: sh:: not found
~ # ~ # Device Role : Active device 3
sh: sh:: not found
sh: sh:: not found
sh: sh:: not found
[quote]~ # mdadm --create --assume-clean --level=5 --raid-devices=4 --metadata=1.2 --chunk=64K --layout=left-symmetric /dev/md2 missing /dev/sdb3 /dev/sdc3 /dev/sdd3cat /proc/mdstatmdadm: You have listed more devices (5) than are in the array(4)!~ # mdadm --examine /dev/sd[abcd]3[/quote]Because there is no prompt ( ~ #) between the 'mdadm line' and the 'cat line', I guess you somehow managed to paste them as one command. In which case '/proc/mdstat' is also seen as specified raid member. Hence the error: "You have listed more devices (5) than are in the array(4)!"The command should start with mdadm, and end with /dev/sdd3
ok thx i try again0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
