parent control not working on multy x.
Sam
When I try to set times (change profile) when internet is allowed it will not let me do this. In the App the message pops up "new profile erstellen" and this is it. It hangs and I need to restart the APP. It used to work but after a reset it is not working anymore. Please help. Thanks.
#MultyX_Jan_2019
#MultyX_Jan_2019
Do you mean you can set parent control rule, but the rule not work?
Is possible to describe your problem more detail? Any steps and screenshots ...?
Which mobile phone and OS version you used? Have you try another mobile phone?
I checked my side, it works properly.
Mutly X is V2.10(ABKJ.4)C0
Apple iPhone XS (iOS 12.1.2) with Multy App V2.2.1.181212.1
ASUS ZenFone 2 (Android 5.0) with Multy App V2.2.1.1812130 -
I can't set up a parent control rule. I can block any device but when I try to set up a profile it won't let me access the menue. I like to set up a Kids profile which allows them every day to have internet access from 08pm - 10 pm. It used to work before but for some reason it won't anymore. All I have changed on my end was a rest and installed all 3 Mutly X's again. Since then it is not working anymore.
My phone is a Huawai P20 Pro (andoid version 9)
3x Multy X - V2.10(ABKJ.4)C0
App verison 2.2.1.181210 (the download link was sent to from Zyxel)
Any ideas ? Thanks much for your support.
Sam
Just noticed that Dexter has a newer App version. Can someone please send me a download link? The Appstore will not update my App. Thanks0
All, nvmd. I have reinstalled the APP and it is working now. Thanks anyway.1
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
