Multy Plus, disable WLAN by timer
Rotsch
Rotsch Posts: 4 image  Freshman Member
edited January 2019 in Multy WiFi System
By Access Control it‘s only possible to disabel a device access.
How can I disable the Admin WLAN, guest WLAN etc. by Timer / Profile?
#MultyPlus_Jan_2019
  • Zyxel_Steven
    Zyxel_Steven Posts: 246 image  Zyxel Employee
    edited January 2019
    @Rotsch,
    Currently, Multy Plus cannot set a Timer/Profile to turn on/off WiFi.
    It only can turn on/off WiFi by manual.
    Can you share the purpose why you need this feature?
  • Rotsch
    Is a power and security part. All is not on, can not be hack and don‘t use power. All devices I can power off, I swtich them off and not let be on power save mode.
  • Zyxel_Steven
    edited January 2019
    @Rotsch,
    Multy Plus is the WiFi system instead of a standalone router.
    It is required to keep WiFi radio on so that different nodes of Multy units can keep connected as a whole system. Once it is shut, there is no way to turn extender node back. Because root node and extender node is used dedicated wireless backhaul to connect/communicate each other.
  • Rotsch
    No
    If the WIFI not in use / using, it is not importent to be avelable the Multy units connection by WIFI. If it musst be on, I would not ask to be possible to disable the WIFI by schedule…. If I power off the Multy Units, I have the problem of none connection to the WAN for the LAN devices…..
