Multy X connects wrongly
Godzilla13
I've had a Multy X System with 3 units for two weeks. On the first floor is the router with one Multy, on the ground floor is the second Multy and the third is in the basement. After restarting all devices, they connect in the correct order. This means that the Multy on the ground floor serves as a repeater for the Multy in the basement. After a certain runtime I have the problem that the Multy in the basement connects with the Multy on the first floor and then of course has a very bad performance, although the device on the ground floor is accessible .
Why is this happening? The Multy on the ground floor has a much stronger signal than the one on the first floor and should be preferred.
Best regards,
Godzilla13
#MultyX_Feb_2019
What do you mean "has a very bad performance"?
Is there any results? Can you share how to test?
Bad performance means bad data transfer rate. I test it with the Multy App or other Apps connected to Multys WLAN. Right now the basement Multy is connected to the ground floor Multy and the performance ist great again. But how long we will see.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
