VMG8825-B50 and Multy Pro app
stefano_sb
stefano_sb Posts: 15 image  Freshman Member
Fourth Anniversary
edited February 2019 in Smart Home Product
Hi, when Multy Pro app will work with VMG-8825-B50? I have it with the latest Zyxel firmware version 5.13(ABNY.0)C0
Stefano
#CPE_Feb_2019
  • AAAAL
    AAAAL Posts: 125 image  Ally Member
    Hi stefano_sb,
    Multy APP can be used on VMG8825-B50B now, you can download and enjoy.
  • stefano_sb
    Fourth Anniversary
    Thanks for the anwser. Are you sure? Android Multy Pro app  version currently is 1.0.5.181012 and it supports only these model and FW:
    - VMG4825/VMG9823 V5.13(AAYC.12) or later version
    - EMG3425 V1.00(AAYJ.13) or later version
    - VMG8823 V5.13(ABEJ.4) or later version
    - EMG6765 V1.00(ABHR.4) or later version
    Last week I tried it (iOS version) . It founded the router but after few seconds it disappear... :-(
  • stefano_sb
    Fourth Anniversary
    Hi, now I can confirm that it works! Is it possible to use a simple user that can only enable / disable guest wifi without sees all wifi settings?
  • AAAAL
    Hi stefano_sb,
    May I have your request more clearly?
    Would you like to limit the access permission on the APP?
  • stefano_sb
    Fourth Anniversary
    Hi AAAAL,
      yes, I'd like to have a user that can only, for example, activate/deactivate guest wifi without access to other informations (like other devices connected, WPA wifi password, etc..). Another thing.... it's not a good idea to save admin password at first access.... I'd like to choose...
  • AAAAL
    edited March 2019
    Hi stefano_sb,
    You can enable a Guest/More AP function via GUI:
    Network Setting -> Wireless -> Guest/More AP
    User connects to the Guest Wifi will not be able to login Multy Pro APP.
