May I have your request more clearly?
Would you like to limit the access permission on the APP?
VMG8825-B50 and Multy Pro app
stefano_sb
Hi, when Multy Pro app will work with VMG-8825-B50? I have it with the latest Zyxel firmware version 5.13(ABNY.0)C0
Stefano
#CPE_Feb_2019
Stefano
#CPE_Feb_2019
Hi stefano_sb,
Multy APP can be used on VMG8825-B50B now, you can download and enjoy.
Thanks for the anwser. Are you sure? Android Multy Pro app version currently is 1.0.5.181012 and it supports only these model and FW:
- VMG4825/VMG9823 V5.13(AAYC.12) or later version
- EMG3425 V1.00(AAYJ.13) or later version
- VMG8823 V5.13(ABEJ.4) or later version
- EMG6765 V1.00(ABHR.4) or later version
Last week I tried it (iOS version) . It founded the router but after few seconds it disappear... :-(0 -
Hi, now I can confirm that it works! Is it possible to use a simple user that can only enable / disable guest wifi without sees all wifi settings?0
Hi stefano_sb,
Hi AAAAL,
yes, I'd like to have a user that can only, for example, activate/deactivate guest wifi without access to other informations (like other devices connected, WPA wifi password, etc..). Another thing.... it's not a good idea to save admin password at first access.... I'd like to choose...0 -
Hi stefano_sb,
You can enable a Guest/More AP function via GUI:
Network Setting -> Wireless -> Guest/More AP
User connects to the Guest Wifi will not be able to login Multy Pro APP.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
