GS1900 series: some improvements of Web interface
Hello, I started to configure my 2 GS1900-8/-24E. Below I summarize a list of all things which could from my perspective be improved:
- Could you add the port name right of the port ID in following screens? I
cannot remember each name behind all of my ports and this would really
help.
a. When I click "Status", I see a virtual device figure with cables plugged in. When moving the mouse over one plug, I see a 3-line text. Port name could be added to the right of port ID
b. VLAN configuration and monitoring menue, each list of "Port"s and "VLAN Port"s (similar to "Port" "Status" list)
c. Loop Guard "Port" list: same as b.
d. Spanning Tree lists with Port ID same as b. - Could you show the blue plugs in the
#Biz_Switch_Mar_2019
Upps, submitted and not finished :-)2. Could you show the blue plugs in the Status screen with different colors per assigned VLAN? Similar to the used cresses in your video at https://support.zyxel.eu/hc/de/articles/360001379273-VLAN-richtig-einrichten-Videoanleitung- So it is directly visible where which VLAN is used. And if more than one VLAN is assigned to a port then each color can be used (maybe max 4 different colors)Thanks for checking ...Siggi
- 588 USG FLEX H Series
- 476 News and Release
